Home > Puma (Tdci) > Hole appeared in rear quarter panel! |
If you look in my build three I did a few pics when I replaced mine. Corrosion warranty is 6 year I’m afraid. Ray
8th Jun 2018 5:22pm |
Birmabright Ally is more corrosion resistant than steel, but it does dissolve once salt gets to it.
8th Jun 2018 10:36pm |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 206 |
Hmmm......thinking about it, I guess that where the body panel stay bolts to the panel creates a nice little niche for muck to settle into, and thus get impregnated with road salt. I’m quite fastidious about cleaning the underside but this area must be getting missed. The hole isn’t too big (big enough though) about 4mm so can probably be filled.
9th Jun 2018 8:36am |
You've also got the potential for bi-metallic corrosion where the steel stay (and bolt) meet the aluminium body, so some sort of isolation would be a good move. I'm a big fan of making rubber gaskets for these sorts of locations.
Unfortunately, Birmabright hasn't been used for Land Rovers since around the late '70's, which is a shame as it was generally a lot more corrosion resistant than what's been used since. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
9th Jun 2018 9:33am |
Thank you for all of your replies.
I will be isolating the bracket to bodypanel joint in due course (although the horse has bolted now I think). I will endeavour to carry out a hole repair and was thinking of some sort of 2 pack filler to do the job. There seems to be a few out there so can anyone recommend a suitable filler from experience? I notice that some fillers actually have aluminium as part of their make up. As the hole is only small (still doing my head in though) I was thinking of using a backing mesh for the filler to stick to? Any ideas appreciated. Cheers. |
9th Jun 2018 1:02pm |
I'd drill the hole out big enough that you lose all of the corrosion to the edge and then stick a piece of ali to the rear of the panel using something like Sikaflex. The hole can then be filled with appropriate filler and made good. Darren
9th Jun 2018 1:35pm |
That’s what I was thinking of, drill out put something on the back (aluminium mesh?) fill hole, sand off and repaint.......stand back and say to myself ‘well Bonny lad you’ve made a right ar*e of that’
9th Jun 2018 3:13pm |
As your gong to have to paint it anyway as they only cost about £20/30 and a few rivets why not just put a new one on? Ray
9th Jun 2018 6:26pm |
I didn’t realise that the quarter panels would be as cheap as that? Food for thought for the future though Ray.
I’ve ground the hole out with my Dremel and it’s about 6mm dia. Put a bit of grey primer on the bare metal and for now popped a neat little black Allen head button screw in with washers and a nut on the back. To the untrained eye it looks like it was meant to be there. I showed swmbo who said ‘where’s the hole gone to?’ .......she didn’t realise that the bolt was the temporary fix bless her. I’m still going to have a look from the back side to see what’s going on, remove the body brackets etc, and the drivers side too because I bet the same thing will happen there. |
9th Jun 2018 7:15pm |
It’s quite common to get corrosion ther unfortunately, as said above with the dissimilar metals and the amount of salt we get on the roads thrown up there they just rot away I think gwyn Lewis do some shields to keep it protected from most of the rubbish thrown at it if you want to stop more rot developing. Ray
9th Jun 2018 7:26pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1566 |
Make sure when you put the steel support back on the U-shape on the end of it doesn’t touch the outer skin of the panel, I find when you get the corrosion there and a hole - a lot of the time it’s from that supports edge rubbing on the wing skin and dirt build up. The bracket gets loose with vibration and corrosion around the bolt is my thought.
You can fix it by getting a bit of aluminium, cutting a strip to size, drilling a few extra holes in it for the adhesive “to leak” through and make a stronger bond. I use a spot welder and a fine skim of quality evercoat filler. You could use countersunk pop rivets for a tidy finish - make sure they’re aluminium ones. Make sure you panel wipe the area first before using the adhesive and filler or it will fail eventually |
9th Jun 2018 11:44pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Also replace the wing support stays with YRM's aluminium version, which reduces the dissimilar metal problem at this location:
https://yrmit.co.uk/product/rear-wing-stay...fender-90/ 2005 Td5 | 90 Station Wagon | Tonga Green |
11th Jun 2018 1:23pm |
Those aluminium stays are a good idea. I’ll check them out prior to doing the job (both sides) just hope that there’s no hidden surprises when I do them.
Thank you for the info. |
12th Jun 2018 9:56am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2287 |
Pictures... SKIP
https://www.defender2.net/forum/topic83242.html |
12th Jun 2018 10:15am |
