Home > Maintenance & Modifications > Terrafirma HD springs |
For your usage, why not stick with original spec. springs? New standard parts will transform it. Darren
8th Jun 2018 6:33pm |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
Yes, am considering that as well, just thought I’d see if anyone has experienced this particular set up, when you think about it my loading is no more than all 7 seats occupied by adults with a small amount of luggage so the standard springs should be ok. 2010 Defender 110 Station Wagon, Santorini Black.
8th Jun 2018 7:16pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Hi Chris
I put HD springs on the back of my110 DCPU and it gave a harsh ride. I tow a big trailer fairly regularly and that was the only time I appreciated them, the rest of the time I’d wince over every pot hole ! I’ve swapped them back to a standard spring but with Bilstein B6 shock absorbers and what a difference to the standard shock, I’d highly recommend Happy searching Rich |
9th Jun 2018 8:04am |
Thanks Rich,
You’ve confirmed what I thought, seems to be the view of most, I think I’ll stick to standard springs with the new shocks, can you or anyone recommend a good brand of, preferably OEM, standard springs? Chris 2010 Defender 110 Station Wagon, Santorini Black. |
9th Jun 2018 9:27am |
You'll probably find that genuine LR ones aren't expensive. Darren
9th Jun 2018 9:45am |
Second that , standard springs seem fine
9th Jun 2018 9:53am |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 |
Originally bought TF springs for my 110 when I rebuilt it but the rears were far too hard. Kept the fronts and replaced rears with new take-off in brown/purple variety, Nice progressive HD spring. I think the green/yellow/green ones offer a bit more comfort though if you are not always towing or carrying heavy loads, but are harder to come by as take-offs. Think mine were £40 the pair.
9th Jun 2018 11:19am |
All sounds good to me, won’t be doing it till start of next month (cash flow 😢) so got a few weeks to get the best deal! 2010 Defender 110 Station Wagon, Santorini Black.
9th Jun 2018 11:38am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
stick with std ones if you can, if you load it up heavy fit the air helpers.
OME shocks will transform it though. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
9th Jun 2018 9:03pm |
