Home > Puma (Tdci) > 2.2 TDCi Oil Cooler Life? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Our 2012 2.2 TDCI 110SW is currently at our local independent having a new output shaft fitted. Whilst talking to him he mentioned he'd just had a Puma with a failed oil cooler which had filled the cooling system with sticky oil which was virtually impossible to clean and ended up having to replace quite a few parts.
I just wondered if anyone has had this issue and what would be the expected life of the oil cooler? Would it be worth replacing? I was driving whilst having this conversation so wasn't paying full attention. As a mechanical numpty I've heard of the fuel cooler, but not the oil cooler? I know our's had the Q421 oil pump update recall done in 2015, is this related? Any info you have would be gratefully received. TIA Photo unrelated but some nice classics! Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
7th Jun 2018 5:34pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3019 |
How long does it take to replace the output shaft?
I think mine needs doing and I'm trying to get an idea of cost. |
7th Jun 2018 5:40pm |
I've left it to the experts, so will let you know when I get the bill!
I did find this though https://www.ashcroft-transmissions.co.uk/f...?769007971 suggesting 3 hours for the Ashcroft replacement so suspect the OEM would be similar? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
7th Jun 2018 5:58pm |
Cheers. 3 hours doesn't seem too bad. Are you going for the Ashcroft part?
7th Jun 2018 6:47pm |
Rightly or wrongly I'm not using the Ashcroft version. I've read a few mixed comments on them. I hope I don't regret this decision! James
7th Jun 2018 9:04pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
there are products that you add to the coolant following a cooler failure that breaks down the oil to aid the flushing process DEFENDER 90 TDCI XS,
8th Jun 2018 6:23am |
Interesting to know, thank you. I am rather hoping to prevent it happening in the first place.
Any comments on when or if to replace gaskets or whole oil cooler as part of a routine maintenance? TIA James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
8th Jun 2018 7:51am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 421 |
Hmm. The spline needs lubrication. I don't know how new grease may enter the spline if not accessible. They mounted an Ashcroft version on mine just a few days ago. JLR themselves - not a local indie. Only time will tell if it's going to be durable |
8th Jun 2018 9:13pm |
I'll be interested to see how you get on with the Ashcroft. Very surprised JLR are using them, almost admitting bad design! Wish id known that earlier, mine was fitted today Lets see who's lasts the longest James
8th Jun 2018 9:29pm |
In order to have them fit the Ashcroft kit I had to be very very persuasive ...
8th Jun 2018 9:38pm |
