Home > Puma (Tdci) > Air-Con Kit DA2344
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Air-Con Kit DA2344
Hi.
Two years ago I had the DA2344 Air-Con Kit installed in my 2007 Def.
I'm quite sure something is not right - for example the fan never kicks in.
I am searching for installation instructions to check if everything is all right.
Thank you for any help.
 Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #711184 7th Jun 2018 2:10am
MGRGPGBG
United States 2009 Defender 110 Puma 2.4 SW Alpine White
https://seriesforever.com/es/index.php?con...achment=10
The link has the instructions as a PDF - this unit is made by Coolair Logan. I am installing this unit in my build right now. The instructions are not all that great, but at least you can try and troubleshoot it. You can also contact them as they are pretty good with getting back to you. I have been working through a few questions with them over email.
Post #711235 7th Jun 2018 12:23pm
Bergos
Thank you a LOT!
BTW. How come you have a Puma Defender in USA? Bergos
Post #711282 7th Jun 2018 6:39pm
Bergos
MGRGPGBG wrote:
https://seriesforever.com/es/index.php?controller=attachment&id_attachment=10
Can you tell me one thing, please? The Electronic thermostat is connected to one of 4 relays. Which one? Is it the one that is powering the A/C pump or the fan?
In my case it was connected to the pump relay and... the pump was not working. I've switched the wires and connected it to the fan relay but now the fan is never working.... Bergos
Post #711285 7th Jun 2018 6:51pm
MGRGPGBG
Replacing my 2.5TD on an 1989 D110 with a used 2.4 and puma bulkhead / dash
Post #711286 7th Jun 2018 6:52pm
MGRGPGBG
Not that far into the installation yet - I just installed the evaporator and am working through the wiring. Contact Coolair Logan directly - they have been helpful. My fuse box has been an issue with items moved and they are helping me with getting it sorted out.
Post #711287 7th Jun 2018 6:54pm
