Home > Maintenance & Modifications > Bulkhead grommet. Madman Install. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
If you’re double jointed yes
I have a set of mole poles and pull the wires through with it. |
6th Jun 2018 6:40pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3995 |
Ive sent a couple of wires through there. Easiest way was to get some stiff steel wire and push it through from the engine side. With the centre console and instrument cluster out you should be able to see your wire, wiggle/grasp it and pull it through into the cabin. You can then attach the wire you want to send back the other way and pull it through. I think it helped a lot if you can get someone else to assist so you have one person on each side. 2007 110 TDCi Station Wagon XS
6th Jun 2018 6:51pm |
It's probably just as easy to take the dash out. It's not as difficult as it looks.
The one on the passenger side is a bit easier to access from inside if feeding cables along the inside of the bulkhead is viable. |
6th Jun 2018 8:53pm |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Yep, I’ve had the dash out a lot, good shout going into the passenger grommett instead,
was looking at that instead, less cables going in there as well. Thanks |
7th Jun 2018 5:39am |
