Home > Puma (Tdci) > TD5 to 3.2 TDCI conversion
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
I have seen a few threads about a puma 2.2/2.4 to 3.2 conversion, and found the MT82 would need beefier bearings installed. Luck would have i where i found a 3.2 ranger and a MT82 gearbox for about 4000 pounds,
I know i would need an ecu calibrated,
-who is able to do that?
The gearbox would have to be upgraded
-Ashcroft?
Could i run the stock TD5 dash or would i have to swap to the Puma dash?
The clutch is also needed, as well as new engine mounts and even gearbox mounts.
What else am i missing?
I am trying to maximize my container shipment so i am not wasting time and money shipping parts across the oceans...
Post #710855 5th Jun 2018 10:06am
zsd-puma
the main reason for upgrading a Puma engine to a 3.2 is it's still a Puma engine and will mate up to the existing mountings and gearbox. You'd probably need the Puma speedo, which pretty much means a whole puma dash.
If you want to upgrade a TD5 there are probably better options. Such as a Cummins lorry engine, which could be fitted for the same or less work. Or just sell your TD5 and buy a Puma Defender.
Post #710960 5th Jun 2018 7:41pm
LANDROVER
I thought that the Ranger was not the ideal engine for the conversion.
I believe that the only successful conversions where done with transit engines and gearboxes. Using a ecu from the transit.
Starting with a factory puma powered land rover.
M & D offer solutions for fitting different engines to the MT82 gearbox and also a 3.2 conversion. I believe they use a standalone ECU to run the engine.
Might be worth contacting them?
Post #710962 5th Jun 2018 7:42pm
NickMc
General consensus is it’s nice to say I’ve a 3.2 Tdci, but it’s not actually that great a conversion and expensive. Much better power plants out there.
Post #710987 5th Jun 2018 9:19pm
JOW240725
Everyone keeps saying they're better conversions, but never say like...? Unless you go full on LS3? Cummins seem too heavy, so what is there? James
Instagram @suffolk_rovers
Post #710990 5th Jun 2018 9:28pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
It’s doable it a cheap conversion if your brave Enuff to do it yourself 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #712839 17th Jun 2018 6:15pm
NickMc
But you’ve got to have the skills to pay the bills like you Steve!
Post #712849 17th Jun 2018 6:44pm
big steve
Maybe so but inc buying the engine I didn’t pay over 5k for my hole conversion ? 2015 2.2 tdci hardtop xs
Post #712850 17th Jun 2018 6:46pm
NickMc
Last time I pass a compliment Laughing
Post #712854 17th Jun 2018 6:58pm
big steve
Thumbs Up simple old wood worker lol 2015 2.2 tdci hardtop xs
Post #712861 17th Jun 2018 7:07pm
