Home > Maintenance & Modifications > Nakatanenga Swingaway wheel carrier |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16858 |
I have a full-width flap and whilst I don't have the Nak swingaway (I have the Sonic3d/Allisport one) I did look into which carriers work with a flap and which don't. The problem is that to clear the flap the wheel has to be either very low indeed (which fouls towing gear when closed) or the carrier has to swing through a very large arc in order to get the wheel outside the envelope of the flap when opened, which tends to make it stick a long way into the road.
As far as I am aware the Nakatanenga one will not allow the flap to be opened, since the arm does not open far enough to clear the arc of the flap, although Brendan will no doubt be along in a moment to confirm this. My Allisport carrier required modification to work, and I moved the wheel much higher and towards the left of the vehicle (when closed) to get the wheel clear of the flap, as well as adjusting the stops to allow the carrier to swing through a much greater arc. The only carriers I know of which will work straight out of the box are the cheapo kind which hinge close to the offside edge of the tub and which require drilling of the tub to fit. I didn't want to drill my tub. |
5th Jun 2018 9:44am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Hi Mike, Peter at Nakatanenga pointed me in this direction.
There is not much to add to BW reply. With a full flap Ifor canopy you need the wheel to swing past the body work. So either the Safari Equip pick up version you may or may not have to remove or extend the wire stop cable. Otherwise you are into modifying another carrier. Brendan |
5th Jun 2018 6:23pm |
