Home > Td5 > Source of water leak and oil leak |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2199 |
Noticed the coolant has started going down on my td5 recently and whilst changing the oil noticed crystals here (lhs of engine above exhaust manifold)
Click image to enlarge Seems a strange place and can't really work out where it is coming from. I assume the fan has blown it backwards but from where? The nearest possible source is the plug in the head inbetween the exhaust ports. However there is no sign of the leak directly around this or below it. Second issue is I noticed a lot of accumulated oil and goo above the canister oil filter sitting on top of the oil cooler block. Is this likely to be the gasket between the cooler and the oil filter housing or elsewhere? Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
3rd Jun 2018 7:25pm |
