Home > Puma (Tdci) > power upgrade |
Cruiser100 Member Since: 26 Sep 2017 Location: N.ireland Posts: 69 |
Have the 2.4 tdci
Whats the first steps in a power upgrade? |
30th May 2018 9:17pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
1) find your wallet
2) contact one of the tuners on here (BAS etc) |
30th May 2018 9:35pm |
Imax Member Since: 09 Apr 2018 Location: South West England Posts: 28 |
I am due to get a remap soon and I was interested in this reply where it mentions "upgrade the adapter shaft from the gearbox"... is anyone able to confirm whether this is really necessary and why would it be required...?
Thanks in advance |
2nd Jun 2018 6:05pm |
Fabio Member Since: 05 Aug 2011 Location: Somerset Posts: 589 |
Mine was remapped by TD5inside and it didn't need any of that.
The adapter shaft was changed at the same time as the clutch. No need to change it before unless it fails. Fabio |
2nd Jun 2018 6:12pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 809 |
Alive have a dealer not too far from you
N. http://www.beyondperformance4x4.co.uk |
2nd Jun 2018 6:31pm |
v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195 |
bas map is fantastic. had mine for about 6 years and i still smile everytime i drive it.
then inter cooler ans hoses. exhaust. not done output shaft 72000 miles. usual clutch change at about 40000. also been 100% reliable. go for it. 110 xs s/wagon s3 swb soft top |
2nd Jun 2018 8:33pm |
The clutch and adaptor shaft are known weak points on standard Defenders.
My point was there is little point getting one remapped if the clutch rattles and the adaptor shaft is throwing rust out the bottom of the housing, because the extra power will just make them fail sooner. |
2nd Jun 2018 11:46pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
first mod without a remap (unless you are driving through water a lot) is the airbox mod, search on here. Makes a difference and costs nowt except about 1 hr of your time. DEFENDER 90 TDCI XS,
3rd Jun 2018 6:20am |
