Home > In Car Electronics > 300tdi headlight/right indicator |
Sounds like an earthing problem. Go round every earth point you can find and make sure they are clean and tight. Ray
26th May 2018 7:23pm |
1. do you have towing electric socket fitted check for water in side socket
2.check earth from lamp holder |
26th May 2018 7:26pm |
(-:AD:-) Member Since: 26 May 2018 Location: Beds Posts: 2 |
Cheers guys,
I checked the earth points, but i suppose what i could do is take a good earth(even straight from the battery to the front/back lights and see if that solves it. Yeah, got a towing socket, all looked okay though, and not an easy one to remove or else ill dissconect. Think its a factory fitted one. Warning lights is a good idea! I know my pannel aint too good. Will have another look tomorrow👍 |
26th May 2018 7:29pm |
