Home > Technical > Grommet |
Sealing Bush,25mm diameter
Body / Batteries & Harnesses Part code 14A7081 |
22nd May 2018 5:21pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Thank you for that. I had a funny feeling you would be the first person to reply.
22nd May 2018 5:43pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4932 |
will, have a sniff about the scrap yards for rovers, As that looks the same grommets that rover use If you can find a metro, that grommet is found behind a the rear bumper, ( where the left hand fog light is) ( not sure I have one spare some where) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
4th Jun 2018 1:16pm |
I've sorted it now but thanks for that, next time I'm in a scrap yard I will acquire some spares 👍
4th Jun 2018 1:39pm |
they're just generic 25mm grommets, most autoelectrics places do them. Or Halfords likely do them in a small assortment box of grommets.
4th Jun 2018 3:04pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
Probably cheaper in the dealers than Halfords these days
4th Jun 2018 9:46pm |
