Home > In Car Electronics > 2 altenators on a td5, is that possible? |
https://gwynlewis4x4.co.uk/product/td5-def...tor-mount/
this set up uses Alt from tdi300 engine but has no vac pump and will need dc load to work with i.e. second battery |
22nd May 2018 8:50am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
An interesting line of thought.
As dorsetsmith has pointed out, fitting a second alternator to the TD5 is easy, courtesy of Gwyn Lewis, provided that you don't have a/c. I am not aware of any other application of the TD5 alternator, and personally have always considered that the alternator with a vac pump stuck on the front is a bad idea. I have replaced two on my 200,000+ mile TD5 Disco, and in both cases the failure was due to oil leaking from the pump into the alternator. It also seems to be impossible to get overhaul parts for these alternators - although I was able to find replacement brushes, when I last looked it was impossible to buy slip rings to overhaul a worn alternator. I wonder if an alternative approach would be to ditch the vac pump and replace it with something else (an electric one, perhaps), and then fit one or two standard alternators. |
22nd May 2018 9:25am |
Thanks Guys,
I am using 2 Optima batteries but straight connected parallel no split charge system. Land Rover used this on the Camel Trophy Discoveries so it must be good for winching power. Can you connect both altenators to the same batteries or will this give problems? Using an 300tdi altenator is an option. I only destroyed one off them in my CT discovery. Do they use the same pully standard? Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
22nd May 2018 10:34am |
