Home > Technical > Td5 brake flexi |
Does anyone know if shb500230 flexi hoses fit a td5 110 ? Or if not does anyone know the correct part number for front flexi hoses for a 2004 td5 110 csw?
Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
18th May 2018 7:22pm |
I wasnt sure if it would be worth putting braided lines on for a standard braking system. The original flexis are fine at 14 years old but I got an advisory for the front brake pipes so thought I'd buy new flexis just to make the job easier. Ray
18th May 2018 8:02pm |
yes 04 and onwards front flexi hoses pipe changed too this type |
18th May 2018 8:09pm |
Hmmmm, mine is a 2004 on a 53 plate Ray
18th May 2018 8:13pm |
Click image to enlarge 04 and onwards front flexi hoses pipe held in place with metal clip at both ends or NRC 7874 on up to 04 |
18th May 2018 8:22pm |
That's perfect thanks I'll get underneith tomorrow and have a look. Ray
18th May 2018 11:33pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5736 |
I like my braided hoses from Llama 4x4 1999 Defender TD5 110
19th May 2018 9:18pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
^^^^ I've already suggested them, I know how good they are too
19th May 2018 9:27pm |
I'll check them out Ray
19th May 2018 9:40pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1566 |
Check if it’s a nut or a clip that holds it on at the spring hanger, that’s the difference in the two hoses
19th May 2018 10:24pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Just a word of warning, my original flexi hose after 16 years started leaking brake fluid due to corrosion... only 2 days after it passed the MOT.
The corrosion wasn't apparent until after it was taken off and MOT inspectors aren't allowed to pull the car apart to find issues. |
20th May 2018 11:25pm |
i had 5 year old braided hoses fail in MOT brake test
21st May 2018 8:05am |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
I think I saw on here the ones that do away with the swivel clip bolt
21st May 2018 8:23am |
