Home > In Car Electronics > Another washer jet query |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
I want to do the mod using the left hand drive wiper holes and install 2 separate jets using front and rear pumps for the windscreen, is it possible just to solder the wires together from both pumps so that both motors work from the wiper push button stalk or will this overload the wiring to the stalk. Jeff
29th Apr 2018 4:47pm |
Why would you want to? If all the kinks are taken out of the water pipe and the none return valve is ok then the pump for the front gives plenty of pressure for two front jets. Ray
29th Apr 2018 5:10pm |
If you did set it up as you describe, you'd have to be careful which way around it's plumbed in. The rear screen pump is higher than the front so that you can't leave yourself without water for the front screen.
As mk1collector says though, the front pump is perfectly adequate. This is the second vehicle I've made the mod to: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Apr 2018 7:02pm |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
I've binned the standard centre washer and moved to jets mounted on the wipers themselves. Locating the jets onto the wipers makes a massive difference - look into the VW type 99 wiper relay too
As for using two pumps - no reason why not if you want a bit more oomf out of them. My mate runs his this way and I'm about to do the same as I've removed my rear wiper totally now. There are a couple of conversion kits out there for a bigger washer jet pump, but might as well piggy back two if you have them for free. Last edited by Maxxed_Ross on 30th Apr 2018 10:48pm. Edited 1 time in total |
30th Apr 2018 2:38am |
Thanks All! Ross It was the wiring I was concerned about, what would happen if the 2 motor connectors were wired together? Jeff
30th Apr 2018 9:15am |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 |
Hi got this mod on the zepplin plenty of pressure using 1 pump and a t piece just make sure the aim is spot on :thumbsup: but it makes such a difference and is so ceap and easy to do every in should do it even put the on the head lamps these are fed from the rear washer
[img]https://www.defender2.net/gallery/albums/userpics/18141/normal_20180430_104557.jpg[/img] WHAT COULD POSSIBLY GO WRONG My sky lantern petition http://chng.it/HJXmZC47 |
30th Apr 2018 10:44am |
It'll increase the load on the wiring, so may be worth looking into a relay if you plan on using them for extended periods My mate who has run this set up for around 5 years hasn't bothered and I'm not going to either |
30th Apr 2018 7:51pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
I reckon this is a dash out job? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
30th Apr 2018 8:02pm |
Click image to enlarge |
30th Apr 2018 10:52pm |
