Home > Puma (Tdci) > Pump learn and Pilot learn 2.4 |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Recently replaced engine, turbo, added Clutch Fix clutch, and intercooler (BAS Hi Flow)
Stretched timing chain - see my gallery for pics. Had recon injectors and a Nakawotsit intake kit to fitted at the same time. Have a BAS2 RRC with a 165 bhp tune. All good. Injector recoding worked. Pump learn failed - cooling and inlet temp. too low, MAF reading 6 eurounitsthingys. Contacted Pete Bell - Temps should be 75c cooling, inlet 15c+. MAF should be around 16. He suggested VCV replacement. Did what Pete suggested - Pump learn completed. However the Pilot learn would not complete, showed "Status 88" on the RRC. Engine sounding sweet and averaging 27 mpg over 2500 miles. E-mailed Pete. The recon injectors were Ford rather than Land Rover, no problem with their operation but they probably stopped the Pilot learn from completing. Not a problem as the Pilot learn would complete automatically over time. I hope that the above info helps someone as tech phobic as me in the future. |
19th Apr 2018 4:00pm |
