Home > Technical > Radio/Clock Fuse keeps blowing
Loz2286
My radio/clock fuse under the seat keeps blowing. Any thoughts?
Thanks guys.
1999 Td5 110 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #701867 19th Apr 2018 4:44pm
zsd-puma
I expect the back of the radio has got water in it. Either from a leaking screen or just from the bulk head vents.
Post #701871 19th Apr 2018 5:30pm
mk1collector
Leave the plug out of the back of the radio and replace your fuse and if it doesn't blow you know it's the radio, if it does blow it's probably the clock. Ray
My build thread
Post #701878 19th Apr 2018 5:47pm
Cupboard
I think that fuse does the interior light too?
Post #701920 19th Apr 2018 9:36pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Yes it does, the wire between my front and rear interior light shorted which caused my radio fuse to blow.
Post #701944 20th Apr 2018 8:24am
Loz2286
That could be it. It first happened after I tried to change the bulb. 1999 Td5 110 CSW
Post #701971 20th Apr 2018 1:43pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
In that case check you haven't bent a terminal in the interior light fitting so it is shorting.
Post #701975 20th Apr 2018 3:33pm
