Home > Maintenance & Modifications > Rear tub corrosion advice
Scott_Landy
United Kingdom 1993 Defender 110 200 Tdi CSW Firenze Red
I've taken out the rear bench seats from my 1992 110 CSW and the Ali tub has corroded around rear bolts as shown in the pics. Any thoughts on what is best to do with it? Does it need any treatment to stop the corrosion now the steel has gone? Its going to get Dynamat and carpet over it so I'm not too worried about how it looks. But do want it to stop corroding and not yet any water in. I wondered about a peice of thin Ali sheet and some decent bonding sealant.
Post #700747 14th Apr 2018 11:13am
mk1collector
I'd cut the hole back to good metal to stop the corrosion travelling, treat the bare edges with something like por 15 then as you say bond and maybe rivet a new piece of Ali over the top then seal and underseal from underneath. Ray
My build thread
Post #700748 14th Apr 2018 11:23am
ssg
I had the same problem a few years back, ended up riveting some of the front bulkhead ali I had just removed over the hole after clearing up the corroded metal and sealing it in with mastic.
Post #700780 14th Apr 2018 2:43pm
Scott_Landy
Thanks for that guys. Time to order some Ali!
Post #700857 14th Apr 2018 8:39pm
zsd-puma
They sell small sheets of ally in most DIY shops.
Being ally you won't need POR15, just rub it down to bright metal and repaint it with a bit of etch primer.
Don't use silicone sealant, use proper body sealer - it doesn't affect paint and sticks better.
Post #700877 14th Apr 2018 10:11pm
