Home > Puma (Tdci) > Spigot bearing help |
'Warm' the end of the crank with a blow torch, I say warm because you don't want the thing glowing red hot.
I assume you have a blind bearing puller? Some good tips here; http://fordtransit.org/forum/viewtopic.php?f=5&t=156612 |
13th Apr 2018 8:21pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Drill a hole in it, there is a void between it and the crankshaft,
Either use a slide hammer to pull it out, Or you can drill a hole to accept a grease nipple and force it out with grease. I did one a while ago, and did post my findings, they are an absolute to remove! http://www.defender2.net/forum/topic51595....ng+removal Good luck 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
13th Apr 2018 8:29pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
There’s a special tool for removing them around £60. You have to shatter the center and then insert the puller.
17th Apr 2018 8:18pm |
