Home > Td5 > TD5 90 Brake Pipes |
Buy a brake pipe set and make your own. It is some work but not difficult. Roel
12th Apr 2018 9:24pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2068 |
As above. Its a daunting task but it is doable, but a decent flaring kit (mines Draper) and a blow torch then take your time!
Or try someone like Pirtek or a hydrualic hose company see if they will make you up a full set of braided hoses! |
12th Apr 2018 10:10pm |
Off side is not too bad only short peace pipe from flex to the comp valve nearside is much longer will need more time had replace a set this month, i removed the pipe off down to local independent LR got them to make up set
(tip make shore you get right end union as around 04 front pipe changed on TD5) |
13th Apr 2018 10:58am |
Defenders are not that bad. I did the rear ones from my D3. Most clambs you cannot touch with your hands.
You can reuse the end unions again. Push the pistons from the brake calipers is as far as possible. When finished you can pump the brake pedal a few times and you have most air in the calipers already. Makes bleeding a lot easier. Use a block off wood or something like that to depress your brake pedal a little to prevent the brake fluid to keep on leaking. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
13th Apr 2018 5:11pm |
