![]() | Home > Maintenance & Modifications > Headlight mod |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hi Scottchad01
They look like JW Speaker 8700 evolution headlights, ![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
Contact Brendan at 4x4 Overlander (site sponsor); Nakatanenga do something similar
http://www.4x4overlander.com/product/herit...-silver-2/ |
scottchad01 Member Since: 17 Jan 2018 Location: North Wales Posts: 94 ![]() ![]() ![]() |
Thanks Jomara but it was the headlight surround and ventI was after (well the non existent one), not the headlight itself, I should have made that more clearer my apologies!
And will have a look into it thank you |
The surrounds look like series 3 ones and the little grill thing looks like something from b and q. Ray
LCJ Member Since: 07 Sep 2009 Location: UK Posts: 201 ![]() |
When I spoke to Twisted about those surrounds they told me that there is welding involved, hence they do not sell them through their shop. I struggle to see what welding could be needed but there we go.
The only other thing I've been able to find is this: https://uproar4x4.com/collections/front-gr...8860357669 |
![]() Click image to enlarge ![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 ![]() ![]() ![]() |
I also spoke to Twisted about those little grilles, they won't sell them separated as mentioned above. I can understand that to be honest as they are the only unique thing about the conversion.
The headlight surrounds are just Series 3 items painted to match the vehicle. These can be had very cheaply, for example: https://www.paintmanpanels.co.uk/shop/mrc8...amp-bezel/ If you are planning to replicate the look, I suggest you look behind your current headlight surrounds first as Land Rover didn't often bother doing a proper job of the paint behind there! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
Nakatanenga supplies at least 2 designs of the flat panel with grille that TD5 and TDCi Defenders need if S3 surrounds are to be used.
That hole for the horn is a nuisance |
Some (not all) Defender wings have a square cut out below the headlamp, presumably for some sort of headlamp wash system. If you have this cut out it would either need welding up or have a new wing front fitted. Secondly the small grilles over the horn apertures would need to be fabricated, that could be the 'welding' they're taking about. But other than that the surrounds are just standard Series 3 surrounds, the front part of the wing is basically the same as the Series 3 you could probably fit series 3 wing fronts which don't have the additional cut outs. The horns could be put behind the bumper or radiator grille easily enough. |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1903 ![]() ![]() |
I have to say, all the technical details aside - I think it's a really great, clean, classical look
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487 ![]() ![]() ![]() |
Evening Guys
I got the look from Series light surrounds and mesh from Halfords bonded on with windscreen adhesive, just make sure it’s in the right position 😬 ![]() Click image to enlarge ![]() Click image to enlarge Life is one big adventure, that's why we have the vehicle for the journey. |
Sunshine Member Since: 18 Jul 2017 Location: Derbyshire Posts: 18 ![]() |
These are on eBay uproar 4x4
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
I was looking to do the same Twisted conversion and the closest I found was TMD, there is no photo on the website but have a look on their Facebook page. https://tmdtuning.com/shop/classic-tmd-light-surrounds/ 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2066 ![]() ![]() |
Photo taken from Landy mag today of TMD advert:
