Home > Technical > 110 TDCi Front Axle - Same as other marques? |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
Click image to enlarge You can buy replacement weld on brackets, £7 or so each. Takes ten minutes to cut old one off and weld on new one, can be done with axle in situ if you remove spring. I did the above last month. Last edited by Lotus_esprit_s1 on 9th Apr 2018 5:26pm. Edited 1 time in total |
9th Apr 2018 5:18pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
You could cut off the item and buy a nice new one to weld on from YRM
https://yrmit.co.uk/product-category/land-...uspension/ £8 +VAT, and only 1-2hrs labour (locally) if you can't do it yourself. Less time and £££ than a total axle replacement. |
9th Apr 2018 5:21pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2231 |
Brilliant! Thanks both
Is this a common issue then? |
9th Apr 2018 7:51pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2548 |
Not on a vehicle as young as yours.
On old Land Rovers it’s not uncommon as they eventually rust or the damper pin wears the hole into an oval. |
9th Apr 2018 8:17pm |
Depends on where you live... the photo above is a 2007 tdci, all four were rotten.
9th Apr 2018 9:25pm |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 484 |
Was the TDCi used by or in the Sea? Working towards Carry on camping!
9th Apr 2018 9:48pm |
No it's spent its life inland really. The other three seem fine but will inspect again on the weekend
Hopefully my trusty Clarke 150 amp is man enough for the job |
10th Apr 2018 11:36am |
