Home > Td5 > O ring failure at the base of rotor filter to oil cooler |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
The threads in the casting can wear some owners drill through and fit nut and bolt
7th Apr 2018 11:30am |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 131 |
I will check he bolts' tightness.
Do you mean the housing can go loose? i had a look again seems like the area of the oil filter housing is covered with a thin film of oil. That gasket was also replaced in February. Could it be that the oil is wearing thin/is thin for our climate here? morning /starting temperatures are anywhere between 12'C and 15'C at the moment, going up to 19'C and 20'C in summer it will be higher of course joe |
7th Apr 2018 1:21pm |
hm i am not sure if i made myself clear. the leak is not from the lid of the rotor filter housing but from the bottom part. see pic for reference. i am sure it is leaking from there - circled in red. as every time i replaced it it stopped . with the 4 mm ring it stayed dry for 2 months... and ring was soaked with oil before installation. is that gallery subjected to high pressure?
regards joseph |
7th Apr 2018 9:28pm |
