Home > Td5 > Handbrake Cable |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 |
Hi
This is a topic that I have been saving in my watched threads, as I will have to do mine. So, I have copied and pasted someone else's text below (I'm not skilled enough to put a link) Hope this helps. Mike Mine snapped a couple or 3 months ago, (TD5 CSW) yes you do need to remove the prop, which is helped massively by having the right tool which is about a tenner online. getting the retaining clips back on the handbrake shoe retaining springs is a PITA, again I think there's a tool for it but I only had pliers etc. apart from that pretty straight forward. Propshaft bolt removal tool helps ( you may have slim sockets but I struggled to get mine on ) SKU: DA1119 Excl. Tax: �9.50 Incl. Tax: �11.40 Bought from Paddocks |
3rd Apr 2018 2:33pm |
adeparko Member Since: 13 Feb 2015 Location: West Lothian Posts: 41 |
Running into problems trying to change the cable today
Bought a tool to remove the prop shaft but it doesn’t cover the nuts? Click image to enlarge I also can’t get a spanner on enough to remove Anyone advise? Thanks Ade |
15th Apr 2018 1:29pm |
9/16 AF ring spanner
15th Apr 2018 1:49pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16812 |
I use a 9/16" AF Snap On flex socket for propshaft fastenings, it works far better than the supposed special tools.
https://www.snapon.com/Industrial-Certific...ex-Sockets I can't link to the specific socket since thd Snap On site is down for maintenance at the moment. |
15th Apr 2018 1:58pm |
I use a 14mm socket that I grinded down a little and lossen the nuts when the are on top. Roel
15th Apr 2018 8:16pm |
Thanks for the suggestions
All sorted with new cable and shoes. Hopefully keep the wife quiet for a bit Thanks Ade |
15th Apr 2018 8:52pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 1994 |
Good man
Glad it went ok in the end. Might get round to looking at mine one day..... Quite like those flex sockets Blackwolf |
15th Apr 2018 9:19pm |
