Home > Puma (Tdci) > hearing the turbo going up en down
Persepolis
Netherlands 2008 Defender 110 Puma 2.4 SW Java Black
Good evening,
I am new to this forum and my English is not great, but I still want to try and join this forum.
I have just bought a 110 Puma 2.4 and I have to get used to the strange sounds. Normally I drive in a 110 300 tdi with sounds familiar to me, engine noise and engine noise.
What really strikes me is the noise of the turbo what is going up en what is going down. ( there is also a whistle in it)
Is it normal that you can hear this turbo sound inside te car?
I checked for leaks at het compressor side. Noting their.
Thank you for reading
Mario
Purmerend
The netherlands
Post #698017 2nd Apr 2018 6:04pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi Mario .. welcome to the forum.
There are 2 things to look for:
1. Check the intercooler pipes for a hole. Normally happens where the intercooler pipe rubs on the steering column shaft coupling
2. Check the joint between the turbo and the exhaust manifold. The faces of both can warp if they get very hot causing them to leak and whistle. If that’s happening you should be able to see soot. You may need to remove the turbo heat shield to see. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #698041 2nd Apr 2018 6:56pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Hi Mario,
Off course you can Pm me in dutch Laughing
No it’s not normal.
As previous poster your exhaust manifold can be warped. But also check the studs Or the bolts between the turbo and the exhaust manifold have a tendency to come loose.
And check the connection between the turbo and the exhaust a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #698044 2nd Apr 2018 7:01pm
Persepolis
Hi Carrobay,
Thank you for your answer.
The pipes and the intercooler are new.
Tomorrow I will check your second point to check. I hope to see no root over there.
Thank you for helping me.
Have a nice evening
Mario
Post #698061 2nd Apr 2018 7:29pm
Persepolis
Tdi4 wrote:
Hi Mario,
No it’s not normal.
Hi Tdi4
I,m not allowed to use the pm! If i try to use PM, i get this message "Sorry, you are not allowed to send private messages. It is likely that you have not yet reached 3 posts on the forum - this is an anti-private message spam feature."
It,s to dark now to check the bolts at the exhaust manifold. I do it tomorrow.
I was happy to hear, that it is not normal that you can hear clearly the turbo inside the car.
Have nice evening.
Mario
Post #698063 2nd Apr 2018 7:45pm
mk1collector
Just a long shot but is it only happening when the stereo is on? Ray
My build thread
Post #698064 2nd Apr 2018 7:45pm
Persepolis
Hi mk1collector,
That was also my first thought. but unfortunately
Thank you
Mario
Post #698073 2nd Apr 2018 7:59pm
Persepolis
Today I went to a 4x4 garage. Conclusion the turbo is whistling.
I have Checked the blades of the turbo. This seems to be fine. No play on the shaft. Continue this research this week
Post #698310 3rd Apr 2018 7:57pm
YOLO110
Australia
As a comment...
When my 2.2 Puma is first started, and driven the first 2-3km, I cane hear the turbo 'whistling' up and down. I had this on my previous Puma so I reckon its normal.
However, once the car is warmed up, I cannot hear any turbo noise.
Cheers,
Peter YOLO... You Only Live Once...
Post #698729 5th Apr 2018 1:43pm
annette
Costa Rica
We had this once with a Puma 2008 ... searched and searched and there was a tiny hole under the jubilee clip that hold the intercooler hose to the pipe Fixing Land Rovers in rural Guanacaste
Post #698740 5th Apr 2018 3:48pm
Persepolis
Hi Annette,
How did you find out where the little hole was?
Mario
Post #698796 5th Apr 2018 9:01pm
Persepolis
YOLO110 wrote:
As a comment...
Cheers,
Peter
I have the same sound with a cold and warm engine.
Most people (experts) that I let listen to the turbo hear a whistle, but do not disturb the whistle.
Post #698801 5th Apr 2018 9:09pm
Persepolis
YOLO110 wrote:
As a comment...
Cheers,
Peter
Post #698803 5th Apr 2018 9:09pm
Persepolis
Update of my search
Today I visited two 4x4 experts.
The first expert heard the whistle, but did not know if this was normal for this type of turbo,s.
The second expert was a 100% Land Rover expert. He did not hear anything special.
He thought the whistle sounded was normal in the turbo
Tomorrow I try to visite a Turbo expert.
Post #698809 5th Apr 2018 9:18pm
annette
Costa Rica
Persepolis wrote:
Hi Annette,
Mario
onder de klemmetje in de slang nummer 3
http://new.lrcat.com/#!/1235/3525/3564/272
een collega heeft me de gas gespeeld tijdens ik onder de defender was. (mijn Nederlands is een beetje roestig, ik spreek beter frans en spaans )
it was under jubilee clip nº3 in this page near the intercooler . Whistled more at about 2500 rpm Fixing Land Rovers in rural Guanacaste
Post #698815 5th Apr 2018 9:28pm
