Home > Puma (Tdci) > Changing rear wiper blade on a 90 |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
Just wondering if I am missing something but is it possible to change the rear wiper blade on a 90 without removing the spare wheel?
I can undo the blade clip but can not slide the blade past the wiper arm as the tyre (265/75 16) is in the way and I do not want to bend/damage the arm. Cheers Don. |
1st Apr 2018 1:12pm |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
I spent a considerable amount of time trying to do this without removing the wheel but had to give in in the end and do it.
I did think maybe the whole arm could be removed with out removing the wheel but I did not pursue it. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
1st Apr 2018 2:00pm |
Nope, you have to take the wheel off. But then again it's not exactly a big job to undo the three nuts and lift the wheel off. Chances are the back door will need a wash and polish behind there anyway.
1st Apr 2018 4:42pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
Another argument for a swing-away wheel carrier.
1st Apr 2018 5:37pm |
Turn the wiper on then switch the ignition off when it's in the upright position 2002 90 Td5 Station Wagon
1st Apr 2018 5:39pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Thanks for the tip 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
1st Apr 2018 5:41pm |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 |
GET THIS GUY A BEER !! so simple, but yet it never crossed my mind |
1st Apr 2018 6:26pm |
Yes, as per grafty99 suggested or, in my case, with the Mantec wheel carrier you can change the blade without take off the wheel Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
2nd Apr 2018 9:58am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2494 |
it's called thinking outside of the box. Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
2nd Apr 2018 10:21am |
Just tried it, it's still tight, but works a treat. |
2nd Apr 2018 6:15pm |
6th Apr 2018 1:42pm |
Nipalong Member Since: 08 Jul 2015 Location: Kent Posts: 29 |
Well, I just change mine, no removing wheel or anything.
7th Apr 2018 9:42pm |
