Home > Td5 > TD5 ABS Fault |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
Just thought I would update this topic.
The diagnostic reader indicated a front wheel sensor fault which was replaced after which the rear wheel sensors indicated a fault. All of the sensors have now been replaced along with the associated wiring harness. So now when I turn the ignition key on the ABS light flashes (system check) and it remains on until the car exceeds 5mph. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
13th Apr 2018 7:26am |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
Good to see a resolution - particularly on ‘mission critical’ parts like brakes, I always get more worried about that sort of thing!
13th Apr 2018 9:22am |
