Home > Td5 > Passenger outside door handle post 2002
Djcla
Hi
My door handle has snapped away from the door and I'm wondering what I need to replace it and is it straight forward?
Not a great pic but you get the idea , I've glued it in the past but that's given up now.
Post #696069 25th Mar 2018 5:00pm
You need a new door handle and yes, it is straightforward. The door handles are all the same, or at least interchangeable, and are secured to the door from inside with two bolts into brass inserts in the plastic. You'll obviously need to remove the door card and moisture barrier to get at them. The biggest problem is usually that the bolts seize in the brass and pull the insert out of the plastic but as your handle is scrap anyway, it won't matter. Darren
Post #696095 25th Mar 2018 7:46pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I changed to lift up doorhandles. They don't get damaged that easy.
 Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #696111 25th Mar 2018 8:35pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
A 2004 from the inside if this is of any help
Post #696120 25th Mar 2018 8:57pm
Djcla
Cheers I've ordered one from eBay for £10 it's not post 2002 but I don't believe there is any difference apart from the locking barrel diameter it takes and my passenger side doesn't have a lock on it.
Post #696122 25th Mar 2018 9:04pm
Roel, you really need to get some new pictures Laughing Darren
Post #696132 25th Mar 2018 9:21pm
roel
Why? I didn't think I used this one before. Whistle Roel
Post #696273 26th Mar 2018 3:37pm
Djcla
Do you just pull/knock the right angle pin out or is there an easier way?
Post #702795 24th Apr 2018 9:59am
You need to prise the little clip off of the shaft with a small screwdriver, or similar. It's fiddly, but easier to put back on again. Darren
Post #702797 24th Apr 2018 10:06am
dorsetsmith
remove the clip with long noses pliers and remove two screw i.e. the rusty one left hand side in your pic ( red )and the one at broken end of your handle
one at broken end of your handle on the inside see below
Post #702800 24th Apr 2018 10:18am
Djcla
cheers, yeah that rusty screw's head is like treacle and needs drilling out Sad.. nothing is ever flippin easy on this car Sad..
Post #702806 24th Apr 2018 10:45am
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
I ordered a second row door handle as it has no lock barrel, and is considerably cheaper than the correct item. The only thing i had to do was to swap the mechanism over from my own door handle
was pointing the wrong way
Post #702807 24th Apr 2018 11:01am
NickMc
Aftermarket handles are junk don’t waste your money the cam on them fouls on the door skin.
Post #702982 24th Apr 2018 11:48pm
Djcla
I ordered a second row bearmach handle (no lock) in the end and it fits just fine.
Post #710404 2nd Jun 2018 7:23am
