Home > Puma (Tdci) > Td5 into a 2.4 Puma? Anyone heard of this done? |
It might be easier to just sell it and buy a tidy TD5, you're pretty much going to have to buy most of a TD5 anyway. Tidy TD5's seem to be about the same money as a scruffy Puma. (comparing like for like)
Cummins engines from a scrap Daf truck aren't that expensive. Prop shafts will also be different lengths I think. |
19th Mar 2018 3:27pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6031 |
If you can get the dash electrics to work (someone on the D90 forum was designing a CANbus unit to work the puma dash with analogue inputs) then I'd go for the OM606a with a Dieselmeken FiP...
Only hardship will be mating it to the gearbox... although the SLK 6 speed (other models also fit, as long as the starter motor mount is in the same position) fits the '606 and works well, so you then need to mate the gearbox to the LT230. 606 is a lovely engine. Revs well and so smooth |
19th Mar 2018 5:08pm |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 |
The type certificate issued will prevent a downgrade of an EU CoC 2.4 PUMA to a TD5. You may go national single permit and that may well render the car totally unsellable. Never forget: cars have owner, Landrover have field service personnel.
31st Mar 2018 2:22pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
Some TD5s are worth MORE than pumas |
31st Mar 2018 5:04pm |
Or just not tell anyone about it, and enjoy driving with the modified engine. |
1st Apr 2018 10:44am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 421 |
Take the TD5, man, and enjoy the fresh air intake
A late TD5 is as good as an early Puma |
8th Apr 2018 11:03pm |
