Home > Td5 > Advice required buying a 90. |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
After some help here chaps. A friend of mine is after a Defender and sent me the link below.
What do you reckon? Is it worth It? http://www.motorseeker.com/used/land-rover.../17962249# 130's have feeling's as well you know |
16th Mar 2018 10:06pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10360 |
Low mileage late td5? Seems on point, then you need the vat on top...
16th Mar 2018 10:18pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
A 2006 TD5 with 49k on the clock. It's not a County and it doesn't have the cold pack, both desirable depending on intended use.
Its not quite "last of the TD5" its from March 2006, mine is March 2007 and was close to being on the same production line as the Puma. However the advertised TD5 is nearing the end of the production but not quite ! Has it got service history ? If all genuine and the chassis and rear cross member are in good order it looks like a reasonable buy. At that milage its just about run in. Price is plus VAT 2007 TD5 90 Hard Top |
16th Mar 2018 10:29pm |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
It's a 10k truck
The paint on the wheels is doge as they've covered the weights with paint. I'd keep on looking as it's way over priced with none of the wanted bits As stated the base model doesn't even have an alarm as standard. Most would want at least county spec for resale value in the future. |
16th Mar 2018 10:39pm |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 148 |
I'd avoid it, last mot was 53618 miles in June 17, I smell a rat. Go for a XS at that price
16th Mar 2018 10:40pm |
Thanks everyone this is really appreciated keep the comments coming 130's have feeling's as well you know
16th Mar 2018 11:01pm |
Zoom in to the odeometer, mileage is 5496x ?
16th Mar 2018 11:05pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
For another grand there's a genuine 90 station wagon in the for sale section
17th Mar 2018 12:14am |
