Home > Expedition & Overland > Hi lift jack safety device
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
This just popped up on my Pinterest page. I thought people on here may be interested.
http://www.exploringoverland.com/overland-...-jack.html
I don’t even own a high lift but I thought this was quite clever, and surprised no one seems to have developed something similar in this country. (Correct me if I’m wrong.) 2002 110 td5
Post #693688 16th Mar 2018 8:16am
That looks interesting. More so that it's five years old but never seen it before. Darren
Post #693715 16th Mar 2018 9:57am
boode
England 2003 Defender 90 Td5 HT Rutland Red
Looks like a good product but at $ 242 its probably too expensive
https://safejacks.com/collections/hi-lift-...or-48-jack
Post #693719 16th Mar 2018 10:14am
I've seen that before.
My initial thoughts were twofold:
It removes one of the key features of being able to use the jack to slew a vehicle; and I wouldn't want to be putting my face anywhere near a tensioned steel cable whilst using the jack.
Looking again, the mechanism for tensioning the steel cables appear to place the load on the outside edge of the rack - that's not a load path the rack was design for.
Post #693768 16th Mar 2018 2:32pm
To be fair, it doesn't remove anything. If you actually wanted to slew a vehicle then you just wouldn't use this particular accessory.
As for the other concerns, as I said it's been around for five years. If it was inherently flawed in the ways you suggest then it probably wouldn't still be available. Darren
Post #693788 16th Mar 2018 5:06pm
Fair point.
but then again, an item that's been around for 5 years, you a LandRover anorak and you say you have never seen it?
Your thoughts on placing your face next to the steel wire under tension?
Post #694003 17th Mar 2018 12:15pm
