Home > Td5 > Adding ARBs Made Worse |
What is worse?
ARB will make the suspension more stiff like a sports car. So if you don't like that it is worse but it should roll less in fast corners. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
12th Mar 2018 3:27pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10359 |
Depends at what you are looking to acheive?
12th Mar 2018 5:50pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
ARBs will make both sides of the axle move in parallel, if a left wheel hits a pot hole it will feel like both did.
On the plus side, ARBs have saved my life on many occasion and will probably save yours at some point. You could try removing just the rear and see if that helps? Should still maintain a lot of the the safety advantages with just one at the front. |
14th Mar 2018 9:34am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2226 |
Did you fit standard ARB’s or “uprated” ones?
1st Apr 2018 9:34pm |
