Home > Puma (Tdci) > Gearbox issues
wyvern
Gearbox issues
Was out for a nice dive over the weekend and comming home from Dartmoor when I had trouble engaging all gears...
My partner heard a 'rattle' sound comming from the gearbox just prior to when the problem started
it felt as if the gate for the gears was in the wrong position and that the leaver was not able to follow the normal line to select the gear. Crying or Very sad
After stopping and wiggling the gear stick with the engine stoped the gears were back to normal and easy to engage for a while but intermittantly caused issues with all gears again.
The clutch seems to be working fine as the engine would drop revs when clutch applied and no 'crucnhing' of gears when trying to select.
My partner took it into the local independant who was up front and said that they couldnt do the job due to the size of the gearbox etc, so have it booked into the main dealers for later in the month...
Sounds like I'll have a nice bill wating for me when I get home! Big Cry Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #63904 16th Mar 2011 1:21pm
MK
I think you should not get revs dropping. The Puma friction plate has a central damper to reduce the noise of input shaft at idle speed. So, it could be that the friction plate is gone or you got a problem in some of the upper shaft bearings (unlikely). IMHO of course.
Did you check the fluid level of the clutch pump? Puma 110" SW
Post #63915 16th Mar 2011 2:20pm
mse
I could be believe its a selector fault...ive had issues with it and got 2 new ones... Mike
Post #63927 16th Mar 2011 3:21pm
wyvern
Hi Mike
I seem to belive your theory is probably correct! it isnt the clutch as far as I can make out .. so hope this is a one time fix! (but it is a landrover so anything can happen!)
Whistle
Hi MK
.. i didnt explain that correctly ... I was refering to using engine breaking and the engine disengaging when applying the clutch ... yep all the fluids are normal ...
it's off to the main dealers later in the week - but as I'm out at work I can only wait for their diagnosis... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #63991 16th Mar 2011 8:52pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Could be the selector gate mechanism. Loads have been known to fail. Fairly easy fix under warranty. Cured my problem. Good luck.
Post #64073 17th Mar 2011 1:16pm
wyvern
shame its a 2007 model ... so out of warrenty! ho hum! Embarassed Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #64150 17th Mar 2011 10:33pm
wyvern
Had the wagon looked at by Roger Youngs in Saltash- tech chap took 30 secs to say it was a clutch issue - so its going in this week for a new clutch (@£706! Big Cry ) and only 4 hrs to do the work.
They are also going to do a free upgrade my software as a standard Landrover issue upgrade ...somthing to do with power
so we'll see how it all goes .... watch this space!!
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #66384 6th Apr 2011 3:11pm
robpenrose
Thats a nightmare mate. Is that your first clutch? How many miles are on it?
Do you always go back to the dealer? I have used a good Indy near Falmouth. Not sure their experience with TDCis, but im sure they are up to speed. Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #66486 7th Apr 2011 9:33am
wyvern
Hi Rob.
yep first clutch - only 53k on the clock on an 07 plate, Embarassed
I saw the clutch once it was out and it had one of the little 'inside' spings rattling round the thing causing some issues, and even I could see the damage on the plates - so better out than in.
At lest can trust it now! Cool
I normaly use independants in Bude and they do a great job, but they said that the clutch/gearbox was to big a job for them - so had to take it to the main dealers
Having said that - I couldn't fault Roger Youngs - the mech took the time to show me the issue, pointing out other faults that they had found caused by work from another main dealer ..... Whistle
yep it cost an arm and a leg - but it drives soooooo much better! I now know what the gears should be !!
Post #66558 7th Apr 2011 7:31pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Hi wyvern
Do you happen to have a code for the latest clutch? I need mine doing out of warranty and don't trust my local LR-Ford dealer to fit the latest version. They've caused so many faults i might even fit it myself. Thumbs Up 130 crew cab
98 V8 Disco
Post #66587 7th Apr 2011 9:27pm
wyvern
Hi Parktag
the number on the bill is 'LLR012199' (P) clutch £205.26
took a total of 5 hrs (with a couple of other little niggles to sort out as above)
hope that helps Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #66619 8th Apr 2011 9:38am
robpenrose
wyvern wrote:
Hi Rob.
Thumbs Up
Well like you say at least you cant trust it. There is something not right with my clutch/flywheel, but as its expensive to repair, i wont do it until its completly gone. Mine only has 60k on it as well! Current:D4 HSE
Gone: BMW Z4MC
Post #66625 8th Apr 2011 10:03am
parktag
Thank's alot wyvern, that's a great help. I'm going to order from the uk and i'll decide wether to do it myself or not later. Thumbs Up 130 crew cab
98 V8 Disco
Post #66762 9th Apr 2011 6:42pm
