Home > Technical > td5 not holding boost |
Might be worth removing and cleaning the map sensor
But it could be a pipe or the intercooler. No strange noises is presume? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Jan 2018 9:14pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Any black smoke?
Actuator move freely? |
21st Jan 2018 9:21pm |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
cor , you lot are fast , no strange noises cos the tyres n straight thru pipe are loud enough , its got a new big intercooler , fancy pipes etc , i`ll change the map sensor , as i have a spare , the one in is clean , a thought , could the turbo not have enough puff with the bigger intercooler i wonder
21st Jan 2018 9:26pm |
no smoke , new actuator , found the old one seized solid at the weekend , hence why my nanocom was plugged in to test n set up |
21st Jan 2018 9:27pm |
New intercooler and pipes would be my fist port of call then. Anything that has changed from before should be the first thing to check. 2002 90 Td5 Station Wagon
21st Jan 2018 9:45pm |
Also if you are running a boost limit box that could have gone faulty. But definately check what's changed first 2002 90 Td5 Station Wagon
21st Jan 2018 9:47pm |
Yeah what boost your running? 18psi is the limit. Any above needs a boost box or uprated MAP sensor + raised boost limit
21st Jan 2018 10:20pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
Leaky new silicon pipes would be my guess. Checked they've not slipped and the clips are tight tight. Then intercooler
21st Jan 2018 11:26pm |
Hello everyone , i’ve Checked the pipes , but will carry on tests after the weekends pay/play day . The boost is around 19psi by google . Ady
24th Jan 2018 7:15pm |
Standard boost on a Td5 is 1 Bar (~15psi) 19psi is right at the upper limit of what the ECU will allow before boost cut strategy kicks in. 2002 90 Td5 Station Wagon
24th Jan 2018 7:22pm |
