Home > Technical > struggling with gears , can not get reverse |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
First place to investigate is the selectors, take the gaiter off the gear lever and then undo the bolts holding the "turret" to the top of the gearbox check that the gear lever is free to move normally. You can see the selector forks, check that each one is working properly.
Good luck. |
20th Jan 2018 5:37pm |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
cheers fella , i`ve taken the top off and it looks ok to me , i have sat n wiggled , found reverse , its not in its normal place and neutral is now up the top , like between 1st n 3rd position , how bizzarre , also noticed , it revs up when lifting my foot off the clutch , never done that before , hmmmmmmm
20th Jan 2018 6:12pm |
When it happened to me (300tdi same 380 box) one of the selector forks was loose on its rod tightened it up and all OK. Seems that yours is not as simple as that!
20th Jan 2018 6:19pm |
Click image to enlarge right head arrow shows grub screw which holds it in place and should be Locktited Last edited by dorsetsmith on 20th Jan 2018 7:09pm. Edited 2 times in total |
20th Jan 2018 7:02pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2548 |
Make sure the yoke is not loose on the end of the selector shaft - there’s a grub screw which holds it in place and should be Locktited. If that’s okay then the problem may lie further into the box as above.
20th Jan 2018 7:06pm |
Thank you everyone popped the top off n found then bits had 99% fell off , the grub was laying there , thank god for that
Click image to enlarge |
20th Jan 2018 7:08pm |
your luck day now fun starts
20th Jan 2018 7:15pm |
all epox`d in , will order some gaskets , she`ll now have new oil too, did a dry run , so to speak , once i had got the mechanism lined up , a git , so gut some metal out , and bobs ya uncle , gears again , yessssssssss .
20th Jan 2018 8:22pm |
