Home > Td5 > Starts then cuts out then re-starts |
1. oil in red ECU plug
2. oil level in sump increasing injector seal failing letting fuel escape down to the sump |
17th Jan 2018 10:07pm |
annette Member Since: 24 Nov 2017 Location: TilarĂ¡n, Costa Rica Posts: 68 |
- bleed the system
- measure fuel pressure. should be 4.2 - check the red connector above your fuel filter. Clean out crap. - what does your pump sound like? Fixing Land Rovers in rural Guanacaste |
6th Feb 2018 4:52am |
Was the fuel purge done after the fuel filter was changed? Ray
6th Feb 2018 10:20am |
