Home > Technical > Exhaust suggestions for Defender Puma 90 2.4 |
I think you will find for best results you need to remove the catalytic converter 2002 90 Td5 Station Wagon
17th Jan 2018 7:52am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2586 |
Yep, remove the cat, and if you want a louder exhaust noise, cut out the centre silencer box and replace with a straight pipe --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
17th Jan 2018 7:57am |
Peterwat Member Since: 22 Jan 2017 Location: Shepparton Posts: 15 |
My local exhaust practitioner is a coward, is the cat conv a combination with DPF? If yes he refuses to remove
17th Jan 2018 10:59am |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
No DPF on a 2.4 just the Cat.
I’m running a straight through system on my 2.4 just with the standard rear silencer in place, still not that noisy but does sound nice under load. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
17th Jan 2018 11:29am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6031 |
Then in 9 months time, change it back to standard because you keep getting a headache from the droning....
My Td5 was like this... went back to standard and got no reduction in performance. |
17th Jan 2018 10:07pm |
Mines ok on a run, you only notice the exhaust note if you have the passenger window down,
Been like that for nearly 4 years now. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
17th Jan 2018 10:16pm |
My Td5 gets on my nerves every few months. I put the silencer back in, am amazed how quiet it is, get bored after a few weeks, then put straight through back on. Then repeat 2002 90 Td5 Station Wagon
17th Jan 2018 11:13pm |
Can do a centre exhaust section change in about 10 minutes now including getting the tools 2002 90 Td5 Station Wagon
17th Jan 2018 11:14pm |
Is there anything available of the sheld here in Oz,preferably in Victoria or online. Btw thanks for the info so far
18th Jan 2018 5:41am |
Meant to say "off the shelf"
18th Jan 2018 5:42am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
I got my centre box pipe from rovacraft, it fitted ok but was a little too long. My thinking it was a generic TD5 one about $90 at the time! However the stainless decat pipe kit came from Alive and was excellent in every way. In addition with the 175hp remap and ultimate intercooler plus silicon pipes. The cat as said for a better sound has too go, this is also a great benefit for heat mitigation with other mods!
19th Jan 2018 2:25am |
Thanks all.
19th Jan 2018 9:18pm |
A couple of post suggest that the cat converter can have the guts bashed out so it is straight through then the centre muffler can be simply replaced with a straight pipe,apparently this modification is pretty cheap and the centre muffler can simply be refitted when or if required
20th Jan 2018 5:36am |
I've removed the cat pipe, all I can see in there is what looks like insect screen. Where is the white substance that one just "bashes out" as discussed on another forum.
Have I been snowed |
21st Jan 2018 3:08am |
