- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
defender9
Wolf door tops - internal thread size | |
A quick question and hopefully someone may have the answer
What is the thread size for the captive nut inside the Wolf door top? This is the captive nut in which the two threaded rods screw into the door top which then fasten the tops to the door bottom.
Thanks in advance.
15th Jan 2018 8:44pm |
Harry.O
Pretty sure they are 7/16 UNF. The parts manual lists them as VYR500010 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
15th Jan 2018 9:55pm |
