Home > Td5 > Hazard and indicator issues
Pardeep
Hi all,
My defender has a strange fault which I am struggling to diagnose. The indicators work fine during normal operation however when the hazard switch is pressed neither the hazards nor the indicators work. I have replaced both the hazard switch and the indicator relay located behind the instrument binnacle. Any help would be greatly appreciated. [/s]
Post #677767 11th Jan 2018 10:01pm
geobloke
Evening Pardeep. According to the wiring diagram there is a satellite fuse (F31) for the hazard switch (15A) attached to a purple/brown wire. If this blows then when the hazard switch is pressed no power gets to the switch or the indicators. However when the ignition is on power will get to the indicators via fuse F21 (10A).
Post #677777 11th Jan 2018 10:20pm
Pardeep
Evening geobloke,
That’s great. I’ll take a look tomorrow and hopefully have it sorted, I suspect it’s going to require getting the modified dash out but I’ll check under the seat first as that’s where the wire seems to be going.
Post #677789 11th Jan 2018 10:47pm
Pardeep
Does anyone know where this inline fuse is? I've had a look behind the instrument cluster, dash, fuse box and under seat fuse box but can't seem to see it anywhere.
Post #683155 31st Jan 2018 4:24pm
dorsetsmith
is your TD5 pre 2001 or post Question
Post #683161 31st Jan 2018 4:50pm
Pardeep
It’s a 2004 car.
Post #683163 31st Jan 2018 4:53pm
Pardeep
It’s a 2004 car.
Post #683164 31st Jan 2018 4:53pm
dorsetsmith
have look below fuse 31 15amp
Post #683167 31st Jan 2018 5:02pm
Pardeep
Ok so I believe it’s Fuse 31 which is in the satellite fuse. Is this fuse 31 in the passenger compartment as that fuse as do all the other fuses seem fine.
Post #683170 31st Jan 2018 5:10pm
dorsetsmith
That`s right shown as satellite fuse. in drawing but in passenger compartment fuse box
Post #683173 31st Jan 2018 5:17pm
