Home > My Defender > Introducing Buggsy my 110 TD5 |
egr is gone replaced with a snazzy removal kit featuring a boost gauge take off
Yea need to look into the possible injector issue I will have a play tomorrow and see if I can find an issue, it may be the loom as it did have some oil in it before I cleaned it, New one should be here early next week so if I can’t find anything I can atleast rule that out once it’s here. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
13th Jan 2018 11:56pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10420 |
Nice one you got Buggsy going Mash
I bet that was great when she started up 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
14th Jan 2018 8:49pm |
Well today I thought I would reprogram the injectors and let the engine come upto temp as I bleed the cooling system, smoke was minimal on tickover and it seemed to be ok, a quick spin produced loads of smoke on acceleration, ok slow down to a trundle only gone a few 100m so far then total loss of power and a locked engine no idea what’s happened, coolant has not dropped oil levels are good, Buggsy was pushed back into her place and I walked away, I guess tomorrow will be finding out what’s wrong now.
Anyone got a spare 15p they want to get rid of? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
14th Jan 2018 10:05pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 4908 |
what a pain in the arse! I have a spare 15p Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
14th Jan 2018 10:15pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4350 |
Nope it is official I am envious... Fed of working by torchlight after work... in the cold... |
15th Jan 2018 8:22am |
Hi Mash. Although mixing green and black injectors will get you home I would suggest that they shouldn't be used long term due to the different pressures they work at; Black at 1500kPa (earlier 10p engine) and green at 1750kPa (later 15p and newer engines). If I recall correctly the green injectors have a longer range of movement in the plunger as well, for better efficiency and power. Best get yourself a couple of replacement green injectors. Also, even if the injectors are not coded to the ECU the engine will run, but not very well; lumpy at idle, slow throttle response and less top end... Check the idle error readings. Should be between -10 and +10 anything over that indicates there is something amiss. |
15th Jan 2018 8:42am |
The engine lockup could be an idler or the alternator, don't think the worst just yet 2002 90 Td5 Station Wagon
15th Jan 2018 9:37am |
Cheers Geobloke knew there was a difference but not the values.
Yea it could be Grafty, I wasn’t really in the mood to whip off the belt yesterday but it’s on the list of to do things today. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
15th Jan 2018 9:44am |
15th Jan 2018 10:00am |
Cheers Procta going out on a limb and thinking you are on about 15 pence aposed to a 15p Td5 Whipped the aux belt off and the rocker cover, and after hanging off the knuckle bar attached to the crank the engine is locked solid, so new plan is buy a replacement engine to get Buggsy up and running then split my block and investigate with a possible option of a rebuild with upgrades ( after Buggsy is fully sorted and Maggie is also). Anyone ever think they have too many projects?...................... Na me either 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
16th Jan 2018 9:48pm |
What's better than 1 project? well 2 of course, then not having a 3rd would just be rude and the forth keeps the others company whilst they are waiting in line...
Or at least that is how it is in my mind... |
16th Jan 2018 10:05pm |
Well I am upto 4 projects not including the 2 running projects I have 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
16th Jan 2018 10:23pm |
HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 746 |
Wow, you the man Mash.
One's enough for me!!! 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
16th Jan 2018 11:21pm |
My mate in South molton is breaking a 2004? Disco 2 if that of any use Mash? 2002 90 Td5 Station Wagon
16th Jan 2018 11:25pm |
