Home > Puma (Tdci) > Door Vent upgrade |
Could be a good upgrade?
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
9th Jan 2018 11:53am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Link? Could be a perfect vent mod for my TD5
9th Jan 2018 12:05pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
Good find Dan
9th Jan 2018 12:34pm |
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 150 |
Here you go, 1 of many links you'll find if you shove 1320206 and webasto into the old search engine https://www.ebay.co.uk/p/Webasto-Air-Top-H...2284718020 |
9th Jan 2018 1:56pm |
You're welcome.... But before you put your hand in your pocket there are some cheaper solutions to be found here http://www.defender2.net/forum/topic33126....=demisters
9th Jan 2018 3:27pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2260 |
Defender lacks of proper vents on the front sides Puma 110" SW
9th Jan 2018 3:56pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
I don't see the benefit of this upgrade? |
9th Jan 2018 4:43pm |
Pre-Puma Defenders don't have any vents to demist the side windows, this would make adding them a little easier.
Probably not much if any benefit on a Puma though. |
9th Jan 2018 7:38pm |
Ive seen that thread, though I wanted a neater more OEM looking solution which this provides, going to use it in conjuction with the MUD vent 2.0, so I can adjust the direction too! |
9th Jan 2018 8:07pm |
