Home > Puma (Tdci) > Drain |
While lying under the truck (or better have the truck up on a post) you should reach with your hand into the cramped space of the transmission tunnel in the middle above the gearbox just after the bell housing. You should find a rubber bung there which can be blocked. Squeeze it open again and you should get a shower of airco evaporation water. The rubber bung is similar to the one on the bottom of the heater intake box. Good luck.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
6th Jan 2018 2:40pm |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 86 |
Thank you very much Eric, very precise your indication, I already solve it. !!!
But what an uncomfortable place! |
23rd Jan 2018 10:23am |
