Home > Technical > Relays 2008 Puma
spudfan
Ireland
Relays 2008 Puma
Could someone tell me what the three relays under the front passenger seat on a 2008 Puma are for? There are two black ones and a smaller grey one. Thanks 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #676125 5th Jan 2018 6:04pm
macfrank
You mean in the battery box? I think there aren't any relays except for one if a 13pin towing loom was fittted. Picture?
Post #676258 6th Jan 2018 6:38am
spudfan
Ireland
You are right! I ment to say DRIVER'S SEAT BOX!!!! Embarassed 1982 88" 2.25 diesel
Post #676302 6th Jan 2018 11:13am
macfrank
Smile Just to make it a little confusing, to me (LHD) it actually IS the passenger side Very Happy and it's called the Battery Junction Box, although the batteries aren't there Rolling Eyes
Anyway, this might help: http://www.defender2.net/forum/topic33868.html
But there are ten relays, not just three, as you mention Question
Post #676364 6th Jan 2018 3:34pm
dorsetsmith
have look at old post below
http://www.defender2.net/forum/topic57192....elays+puma
Post #676378 6th Jan 2018 4:45pm
spudfan
Ireland
Many thanks. I'm actually looking for the wiper relay. I have a problem and I need to figure out if it's the relay or the switch. Thought it would be easier to swop the relay from a second Puma to see if it is the relay. If not I'll order in a switch. 1982 88" 2.25 diesel
Post #676383 6th Jan 2018 4:52pm
dorsetsmith
i will find you under dash relays i think wiper relay in this place
one drive not work Rolling Eyes
i think second row down second one from left under dash relays
Post #676384 6th Jan 2018 4:56pm
macfrank
Ah, so the BJB was changed with the 2.2, not with the 2.4?
And the "Central Junction Box" under the dash?
Here it just says "2007-2016" and it looks like my 2015:
https://www.landroverworkshop.com/diagrams...uses_44949
There top row is (from left to right):
D247 timer heated front screen
D113 delay windscreen wiper
R141 relay hazard warning
Post #676453 6th Jan 2018 9:13pm
spudfan
Ireland
Changed the relays and the problem was still there so I must order in a wiper switch. Everything works except for the very fast wiper action. It does not bother me but it is probably a fail in the vehicle test, ie the M.O.T
Thanks to all who contributed. 1982 88" 2.25 diesel
Post #676580 7th Jan 2018 1:42pm
