Home > Puma (Tdci) > emulsified oil on filler cap |
That's usually what does it. Is the thermostat stuck open? That'll make the problem worse as it'll never heat up. Clean it out again and take it for a few longer runs, ie. take the long way home a few times and see if the problem still manifests its self. It'll do the car the power of good anyway. |
4th Jan 2018 2:38am |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
it needs a good run to start with its not getting chance to get warm if it continues a pressure test might be a good idea to check if head gasket is OK .but to be honest i think it needs using more
4th Jan 2018 8:43am |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
Took a photo this morning -this is 90 miles and three weeks after oil change and cleaning the cap.
I did think it doesn’t get run enough, it actually does well under a mile a day under usual use, however my 2015 2.2 has the same low use short journeys yet has no mess under the oil cap? Click image to enlarge |
4th Jan 2018 10:10pm |
As i said the thermostat could be stuck open and it's not heating up at all. The thermostat is probably working properly on your other one.
Under a mile a day is still not going to do either of them any good, clean the cap out and take it for a longer run so it gets up to temperature and see if it still filled up with mayonaise afterwards. 90 miles is irrelevant if it's had 90x 1 mile trips, it's far worse for it than a single 90 mile trip. It'll also be coking up inside the engine, with the constant short runs. |
5th Jan 2018 1:37am |
That kind of emulsified liquid as shown in the picture cannot just be engine oil alone, can it? Looks very much like emulsified oil and water (coolant?) to me.
Edit - My truck is parked at home under car port like conditions and I often do not use it for a few weeks at length. So temps are getting quite cold in the winter. Just went checking inside of the oil cap, no sign of any condensation there, just a bit of clean oil. So seems you may have a bit of a concern there. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 5th Jan 2018 10:35am. Edited 1 time in total |
5th Jan 2018 7:37am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7686 |
With recent weather it did he condensation but that looks like a large build up for that. When was the last time the truck got up to temp on a run, how many miles did that take? And whats it look like in there after a 50 mile single run? After same run any excess Pressure in coolant system? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
5th Jan 2018 7:55am |
there is quite a bit there i think a pressure test to check the head gasket are you having to top the coolant tank up ?
5th Jan 2018 8:37am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
With so little use and not getting up too temperature, changing the oil won’t get rid of all the sludge. As said if the coolant is good I think a good run get it hot keeping close look how hot. They will do short journeys, no worries but in between they need too work! Other problems can arise with diesels that are lightly used. still a good chance it isn’t the CHG.
5th Jan 2018 9:38am |
gone quiet, maybe its fixed? Cheers
7th Jan 2018 8:32pm |
I am away for a few weeks now, I cleaned it up on Friday but it hasn’t been used since,
I will give it a few long runs but I do think it is a bit more than just condensation as my 2.2 does exactly the same short journeys only and is spotless |
7th Jan 2018 10:15pm |
8th Jan 2018 11:07pm |
