Home > In Car Electronics > Dab SPlitter Cable info only |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
In case anyone comes across this thread i can confirm that the connects2 DAB splitter cable so far seems to worked for me with the stock aerial on my TD5, so no need for a second aerial.
https://www.dynamicsounds.co.uk/connects2-...itter.html |
3rd Jan 2018 5:16pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2003 |
I’m using this one, seems to work ok most of the time:
http://www.dabonwheels.co.uk/Kinetic_DAA-7...itter.html |
3rd Jan 2018 6:10pm |
They are probably all pretty similar there is an automated one as well.
3rd Jan 2018 6:17pm |
I keep meaning to get one of these, I found that the signal was pretty poor with a windscreen mounted one 2002 90 Td5 Station Wagon
3rd Jan 2018 7:00pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2225 |
I am planning on moving to DAB and want to retain the OE aerial, is this still performing well?
Cheers |
15th May 2018 9:24am |
Yeah it's fine, some times when I start up it says no signal for 30 seconds but then sorts itself out
15th May 2018 10:49am |
Thanks. Have ordered one... Just need a DAB head unit to suit now!
15th May 2018 12:43pm |
I bought this one, along with JBL speakers and a small Kenwood sub
http://www.halfords.com/webapp/wcs/stores/...reId=10001 |
15th May 2018 12:53pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3693 |
Maybe a silly question
I'm looking at a new radio with DAB+ Do I need a splitter to connect to my existing aerial and use a windscreen mounted DAB one? Or will the window mount one do normal FM and DAB+ Thanks For the head unit I'm looking at I was told this one... http://www.halfords.com/technology/car-aud...bestseller |
23rd May 2018 9:50am |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
I fitted that one on the alpine window and connected to the DAB aerial input on my headunit then the existing wingtop one connected to the analogue input on the headunit. Keith
23rd May 2018 10:00am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
The stick on window mounted aerial is designed for DAB use only. You would still need the existing OE aerial for FM. The splitter allows the use of the original aerial for FM and DAB thereby eliminating the need for the stick-on aerial. Works for me |
23rd May 2018 10:48am |
As above
23rd May 2018 7:25pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2069 |
dito ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
23rd May 2018 9:52pm |
RockfieldWines Member Since: 13 Feb 2014 Location: Monmouth Posts: 29 |
I took mine into halfords to have DAB radio CD etc fitted and after 2 hours they stated there was no location where they could get the aerial signal to work so they refunded me. Where do other people place thiers
24th May 2018 12:16pm |
