Home > Td5 > Td5 10p engine locked up HELLLLPPPPP |
does it turn over with the auxiliary belt removed? 2002 90 Td5 Station Wagon
2nd Jan 2018 8:56pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4395 |
When you turn the engine over in reverse is there any noise from the bell housing? Thinking it could be a fly wheel issue. They do disintegrate, it is not beyond the release of possibility that it would prevent the engine turning over.
2nd Jan 2018 9:16pm |
Jeevo2001 Member Since: 31 Dec 2016 Location: Birmingham Posts: 25 |
thanks
Cant hear anything from the bell housing, but il have a listen to it tomorrow. Iv not removed the auxillary belt that was going to be my next step before checking the oil pump. I wasnt sure if there was enough resitance to lock the engine up, but was going to give it a try |
2nd Jan 2018 9:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7686 |
I had a td5 come in with seized engine, turned out to be collapsed tensioner bearing. Aux belt off and it started straight away! Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
3rd Jan 2018 7:56am |
Amazing that a collapsed tensioner pulley could resist the starter motor... Hope it is as simple as this to sort out
3rd Jan 2018 12:34pm |
Il give it a go when I get home from work.
Yeah I’m amazed it could be I assumed it would have snapped the belt Hopefully it is a quick cheap fix so I can get it to wagtail on the weekend |
3rd Jan 2018 12:38pm |
Cheers guys found the culprit
Idler bearing £7 fix 😄. |
3rd Jan 2018 5:31pm |
thats great news.
in the case i had come in the bearing seizing stopped the engine! Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
3rd Jan 2018 7:41pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
Forum help at its best
3rd Jan 2018 7:48pm |
Great help from the forum
Woulda ended up pulling he engine out the way I was approaching it |
3rd Jan 2018 8:01pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
Were there any symptoms before hand? Squealing belt or squealing pulley sounds?
Mine has been making these noises for the last few weeks when the weather started getting colder....should i be worried? |
3rd Jan 2018 8:21pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3463 |
Top fix 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
3rd Jan 2018 8:34pm |
No real symptoms
I had noticed a very slight noise but nothing, |
3rd Jan 2018 9:31pm |
Fan blooming tastic... Well done JST good call |
3rd Jan 2018 9:46pm |
