Home > Td5 > TD5 possible performance issues |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Check the usual
- oil in the red plug of the ECU, if so then replace the injector harness - Clean the MAP sensor on the inlet manifold - check for blockages in the air intake - check for any leaks/splits/delamination of the turbo hoses - check the wastegate on the turbo is free, lube up anyway - check the EGR isnt blocked if fitted. If not then blank off anyway - is the MAF sensor genuine? |
2nd Jan 2018 1:05pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
thanks ill look at all that , ill have to work out where each item is first as im a newbie at this stuff but learning How would i tell if the MAF is genuine is it obvious looking at it?
2nd Jan 2018 1:16pm |
Genuine ones will have VDO Siemens marking on them somewhere. If replacing only replace with genuine 2002 90 Td5 Station Wagon
2nd Jan 2018 1:24pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
The whistle could be from a warped exhaust manifold, but should do it at related engine revs as opposed to speed. Look for soot marks on the engine side of it. Whilst checking the hoses, make sure all the clips are tight and they haven't slipped back.
2nd Jan 2018 2:11pm |
ECU is under the drivers seat Injector harness is under the rocker cover, top of the engine. Very easy to change - Clean the MAP sensor on the inlet manifold Inlet manifold is on the left of the engine if looking at it face on, sensor is in the middle - check for blockages in the air intake - check for any leaks/splits/delamination of the turbo hoses Locate the turbo on the right hand side of the engine, follow the soft rubber hoses thru the engine bay - check the wastegate on the turbo is free, lube up anyway Check google for pics - check the EGR isnt blocked if fitted. If not then blank off anyway Plenty on youtube for this one. Landrover toolbox videos are a great way to learn. - is the MAF sensor genuine? |
2nd Jan 2018 5:17pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
My td5 was slightly sluggish but the alternator died which was replaced as was the battery and then added one of those engine additives but now she flies....but not sure why
3rd Jan 2018 6:22pm |
My alternator belt squeels when cold but seems to fix itself when warmed up.
3rd Jan 2018 6:24pm |
It might be more of a wurng kinda noise hard to describe tbh. |
3rd Jan 2018 6:26pm |
Hi
I'm convinced the MAF is duff on my car it makes little difference if it is connected or disconnected. It's getting power I've checked that on multimeter. How do I tell if it's duff or not though for sure? I saw a video showing to disconnect it while engine running and if engine stalls it's working, is that right or will I do damage? |
28th Jan 2018 9:00pm |
