Home > Td5 > LT230 Transfer box question |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 341 |
I'm about to fit a Disco transfer box to my Defender and have a question. The power take off point has a cover that is bolted on had a squirt of mastic (RTV) around the mating faces to keep the oil in. The unit that this bolts to (bearing/shaft housing) that has the bearing face for the input gear has no sealant, it looks just a "good" machined finish. Is there a need to try and RTV this part to the box or has someone been in here and not refitted gaskets? Mike
Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
18th Dec 2017 10:22pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16870 |
Prior to transfer box serial number 288709E there should be a gasket fitted, from this serial number use Hylosil 2000 for bearing housing.
For the cover plate use Hylosil RTV 102 on all. |
21st Dec 2017 1:05am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
^^^^Yup what he said...^^^^. Just torque it correctly.
Good luck! 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
21st Dec 2017 9:40pm |
