Home > Technical > Leaking sides to rear tub sealing advice |
I would be inclined to put more bolts in 2002 90 Td5 Station Wagon
18th Dec 2017 5:06pm |
Having said that I put new seals in mine when I rebuilt after the respray. They're really thick (40mm or so) 2002 90 Td5 Station Wagon
18th Dec 2017 5:07pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
It has the correct bolts and brackets George. Additional ones would have to be drilled, not the easiest and permanent holes I'm sure I've read somewhere on here , someone used sikaflex? I know k9(mal) was an advocate of it. The only problem is splitting at a later date! It's just one corner and under the rear quarter light.
18th Dec 2017 6:59pm |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 616 |
I would unbolt it, replace the seal, and then check for rust/other issues. the standard seal is good except for the one spot by the seam of the cappings. you can add a bit of sealant, but something is cleary wrong fundementally if it's leaking.
It's an hour's work and parts are cheap. V8 90...WIP |
18th Dec 2017 7:09pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10358 |
Masking tape, upper and lower part of gap, apply silicone liberally in one big line with BARREL gun (skeleton guns are a waste of money and effort) lick finger and smooth it in in one big line. Peel masking tape off.
18th Dec 2017 7:10pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Sikaflex mastic is a great product we use it a lot at work, it’s easy to finish (like bathroom sealant) but does stick like to a blanket very waterproof, very flexible, very good product 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
Here was my result.
Click image to enlarge |
18th Dec 2017 7:12pm |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 510 |
Jim, I had a leak under the rear quarter light (near side) and I thought it was the tub seal, put some dum dum around the inside of the light, no more leaks, worth a try Cogito ergo sum
18th Dec 2017 7:14pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
Greeni has made a very neat job, But I would put new a seal in as mastic is quite severe
18th Dec 2017 7:22pm |
Knew I'd seen it somewhere Thanks Greeni. Trade tip - Better than licking your finger, use a spray mister, with some water and a few drops of washing up liquid |
18th Dec 2017 7:28pm |
My fingers usually are sticky from sticky buns. I appreciate the tip though
18th Dec 2017 7:41pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1749 |
I do the same as greeni but use a polymer sealant instead of silicone. I also do the front bulkhead.
18th Dec 2017 8:30pm |
Plenty of different brands of proper car body sealer available for the job.
Silicone is a nightmare if you ever have to have any paintwork done. |
18th Dec 2017 11:55pm |
Quick update,
Rear tub sorted, new seal sorted that. Now found another leak Drivers side roof to windscreen , leaking in the corner where the dum dum has deteriorated and disappeared, dug it out and cleaned up and resealed with sika ......... fingers crossed |
6th Jan 2018 1:52pm |
