Home > In Car Electronics > Alpine head unit recommendation |
churchy Member Since: 28 Jul 2011 Location: UK Posts: 236 |
Anyone got either of the below head units? Need to combine with the dab aeriel too so recommendations would be very welcome!
Thank you! https://www.caraudiocentre.co.uk/search.as...ageItem=12 https://www.caraudiocentre.co.uk/product_m...-32981.htm https://www.caraudiocentre.co.uk/product_m...-40394.htm |
24th Nov 2017 10:58am |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
I’ve got the CDE196DAB - nice unit, works well. I’m happy with it!
24th Nov 2017 11:01am |
Thanks Jeremy - did you connect to existing aeriel (metal one on wing) or add another? Bit of a novice at this!
24th Nov 2017 11:13am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 663 |
I have an Alpine UTE-930AB head unit works well, I like it, its fed from an aerial splitter like this...
http://www.caraudiodirect.co.uk/dab/autole...l-splitter I had an adhesive aerial on the windscreen for a little while, nowhere near a good |
24th Nov 2017 1:17pm |
I dont see why not
9th Dec 2017 10:12am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
From reading others post it appears to. It might be worth replacing the currant aerial for a new one at the same time, as Bob did it on an older aerial without success, but after replacing the old aerial it worked Not something I've tried. I currently run mine with this - http://www.halfords.com/technology/car-aud...ab-antenna .
I tried the screen mount with little success, being a sunday and desperate whilst all the dash was in bits I rolled the dice, with the view Id get a roof mount one later. It works a treat I have it mounted above the rear door, bent at 90 degrees. A metal plate gaffer taped behind the headlining is enough to hold it. Perfect reception 99% of the time and no height restrictions. Bobs thread -http://www.defender2.net/forum/topic31762.html?highlight=dab+splitter |
9th Dec 2017 10:14am |
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 103 |
Got the UTE93DAB works well. All my music is put onto a memory stick to save storage and any dust problems. Have got a roof mount aerial with magnetic base (as above from Halfords), attached a small piece of steel to my roof rack to give it somewhere to stick to.
9th Dec 2017 11:51am |
