Home > Puma (Tdci) > Rear side door hinge bolt seized |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
So the Puma is booked in for Zagato treatment.
Good time to change all the hinge bolts for Stainless. All bolts changed fairly easily except, naturally, the last one. Near side rear lower hinge to B pillar. Upper hinge captive nuts easy to access from inside the Land Rover, this one appears to have no access to the captive nut, and it's seized solid. Before I attack the bolt with a drill is there any way to get at the captive nut? Which, now I think about it, will probably need replacing as well. Maybe leaving it to Chris (Zagato) would be the best option. I'd be grateful for any advice from anyone who has solved this problem. |
20th Nov 2017 2:22pm |
Thanks
20th Nov 2017 3:43pm |
